| How To Fix Nintendo Switch OLED With No HDMI Output | |
| Device | Nintendo Switch OLED |
| Difficulty | ◉◉◌◌ Medium |
| Type | BGA, Soldering |
- Symptom 1 (Figure 1)
- Symptom 2
