| Type | Component |
| Device(s) | Resistors |
What is a Resistor?
Resistors in schematics look like in Figure 1 and are usually denoted with the letter R followed by an identifier number. (E.g. R381)
Voltage divider
Uses:
- And much more
Resistor sensors
Pull-up / Pull-down
Pull-up and pull-down resistors are commonly used in digital electronics to ensure that a digital input signal is in a known state when it's not actively being driven by an external source. They are essential for preventing floating or undefined states A pull-up resistor connects a digital input to a voltage level (usually Vcc, which is the supply voltage). This effectively "pulls up" the input to a logical HIGH state when the switch or sensor is not actively grounding it. Pull-up resistors are often used with switches and sensors that are normally open. When the switch is closed or the sensor is active, it grounds the input, causing it to read as LOW. When the switch is open or the sensor is inactive, the pull-up resistor ensures the input reads as HIGH. A pull-down resistor connects a digital input to ground (GND). This "pulls down" the input to a logical LOW state when the switch or sensor is not actively driving it HIGH. Pull-down resistors are typically employed with switches and sensors that are normally closed. When the switch is open or the sensor is inactive, it keeps the input grounded (LOW). When the switch is closed or the sensor is active, it drives the input HIGH. Usually, pullup or pulldown resistors are 2.2k to 10k ohms.
Current measurement
Fixed value resistors
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors (LDRs)
Testing a resistor
- It's important to note that when measuring a resistor, polarity is not a concern.
- Ideally, you should measure the resistor outside of the circuit.
- Resistors typically fail in an "open" state, which means they will exhibit a significantly higher resistance than normal or even an open circuit.
- This is often a result of excessive current causing them to overheat.
- Rarely, resistors might exhibit a Value Drift
- Over time, a resistor's resistance value might change due to environmental factors or aging.
Replacement considerations
