RTX 3070 Not turning on, short on 12V Repair
Revision as of 16:57, 13 February 2024 by ASRepairs (talk | contribs)
Device RTX 3070
Affects part(s) PowerStages, Shunt resistors
Fixing an RTX 3070 that showed shorts to ground on 12V from the PCIE lane and one of the 8-pin connectors. The 5V coil also seemed low (~59 ohm).
RTX 3070, shorted PowerStage (Figure 1)
  • Sub 100 Ohms on either 12V from PCIE slot or external 8 pin connector(s)
  • Card not turning on or PC shuts off immediately after turning on
  • Shunt resistor(s) likely blown
  • This is HIGHLY likely to be a dead PowerStage/MOSFET.
  • To identify which one, see Short Circuits - Repair Basics. You'll need to inject 1V and check for hotspots with either Isopropyl Alcohol or thermal camera.
  • Cases like these sometimes have the MOSFET short to OUTPUT instead of GND. This means any voltage injected above 1V might damage the core.
    • The best way to safely inject voltage is to connect the negative (-) lead from the LBPSU to the VCore rail, this ensures that VCore will always be at 0V and all the current will return to the PSU before reaching the core.
  • Replace the identified shorted PowerStage. In this particular case, 2 were shorted, first bottom one for the PCIE slot and 3rd one for 8 Pin connector.
  • Check if the short is still present, if not, power up the card and measure all the voltages.
    • If you're missing a voltage rail, this means there is another issue, check the device's page for more guides.
  • If everything is okay, assemble the card and stress test.
