IPad Pro 12.9 5th Gen Touch Screen Not Working
Revision as of 00:54, 24 January 2024 by KevinShort (talk | contribs)
Device IPad Pro 12.9 5th Gen
Affects part(s) Motherboard
Needs equipment Multimeter, Soldering Iron
Fixing a problem where the iPad turns on but the touch screen does not respond to any input.
  • Non working touch
Check for shorts on the capacitors near the two BCM15957A0 touch controllers above the lower display connectors. Often there will be a failed capacitor causing no touch.
