| Sony WH-1000XM3 Headphones Charging but Not Turning On Repair | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
How to fix Sony WH-1000XM3 headphones that will not turn on.
- Will not power on but appears to charge (red charging light comes on and stays lit).
- Use a multimeter to check the battery. Battery should read between 3.7v and 4.2v. If it's outside of this range, replace battery with another one.
- Check connections, check unit for signs of water damage.
- Assuming all the above stuff is good, you have a dead L_MAIN board, replace L_MAIN board. The service manual says you can't but you can. Just make sure you solder all wires in the correct order.
