How To Fix an iPhone 7 That Does Not Turn On, urrent jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on
Revision as of 20:45, 20 January 2024 by VCCBoardRepairs (talk | contribs) (iPhone 7 No Power current jumps back and forth from 0 A to 320 mA, then 0 A to 1.4 A, then 0 A to 500 mA, and so on)
Device
Affects part(s)
Needs equipment
Difficulty
Type
  • Symptom 1 (Figure 1)
  • Symptom 2
