How To Fix an iPhone SE 2020 That Randomly Restarts | |
Device | iPhone SE 2020 |
There are many reasons that could cause an iPhone SE 2020 (2nd Gen) randomly restart every few minutes. For the iPhone SE 2020 there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone SE 2020 is:
- Bad or Defective Battery - If the phone is not showing a percentage at the top of the screen, it means the battery data isn't being read by the device, causing the device to restart. So if you see your iPhone SE 2020 says it's charging at 0%, that could be why it's restarting.
- Motherboard Issue - There is a common fault on these logic boards, causing the 3 min restart issue. It's due to a defect in the logic board.
- After a hard drop & the back glass breaks, the phone will restart every 3 min.
If you see:
- Check the mosfets Q3201 or Q3200 to see if broken or damaged
- Check the battery data pins (I2C3_SMC_TO_GG_SCL_CONN and I2C3_SMC_BI_GG_SDA_CONN) for a diode mode reading. If it's OL, then there's a disconnected line & it'll need to be investigated
- Mic1 - When it's related to the charging port flex
- Test with known good charging port flex. Replacement flex cables can be defective & very common, especially if it's an iPhone 8 charging port flex, it may cause restart issues on iPhone SE 2020
- Mic1 - When it's a broken trace within the motherboard
- Refer to this guide for more details: IPhone SE 2020 3 Long Jumper Solution To Fix No Touch and 3 Min Restart
- Diode Mode the charging port FPC & check these 2 pins (I2C1_AP_SDA & I2C1_AP_SCL), as they're the Mic1 data lines. If you see one or both as OL, then you have the common logic board defect. There is a break somewhere underneath the SIM Tray. So the solution would be to run a jumper around it to bypass it. Here's how:
- I2C1_AP_SCL - Run a long jumper from R6610 to pin 13 on the charging port FPC. If done correctly, you should have a Diode Mode value of .329V at the charging port FPC
- I2C1_AP_SDA - Run a long jumper from R6611 to pin 15 on the charging port FPC. If done correctly, you should have a Diode Mode value of .329V at the charging port FPC
- Bad or damaged flex
