IPad Pro 12.9 No touch after screen replacement repair
Revision as of 01:25, 18 January 2024 by KevinShort (talk | contribs) (KevinShort moved page IPad Pro 12.9 No touch after screen replacement to IPad Pro 12.9 No touch after screen replacement repair: added repair to the title)
Device IPad Pro 12.9 1st Gen, iPad Pro 12.9 2nd Gen
Affects part(s) motherboard
Needs equipment soldering iron
Fixing an iPad Pro 12.9 that no longer responds to touch input after a screen replacement / device disassembly.
  • Non-working touch
If there is no touch after attempting a screen replacement with a known-good screen, most likely the screen was connected/disconnected with the battery plugged into the board. This can result in a blown touch filter on the far end of one of the display connectors. Replacement of this component will often times resolve touch issues.
