| Avatar Goggles X | |
| Manufacturer | Walksnail |
| Code name | |
| Release date | |
| Device type | Drone |
The Caddx Goggles X are the replacement for the original Walksnail Avatar HD Goggles.
These new goggles have an all new design, are manufactured by Caddx FPV and feature
Product Features:
- 1080p Oled Displays 50 degree FOV +2 – 6 Diopter
- Upgradable Avatar HD VRX Module with DVR
- Analog Input via 3.5mm Jack ( No Analog DVR Onboard)
- HDMI In & Out 720/1080P 100/60fps.
- Proximity Sensor
- Wifi & Bluetooth
- 7-26v 2-6S Compatible
These goggles are fully compatible with all existing Avatar HD VTX’s with the standard VRX.
Upgradability
The New Goggles X feature an top mounted VRX module accessible with 2 screws. Caddx FPV have stated they intend to release a new upgraded Avatar System and new module for these goggles mid 2024 with improved range (20+km) however compatibly with existing vtx or cost is unknown.
●Weight 290g
●+2 to-6 diopter
●FOV 50°
●Lenses can be replaced
●7-26V
●1PD57~72mm
●Front cover DIY
●Infrared Sensing
●1080P/100FPS
●Sharing mode
●HDMI input
●Replace VRX
●HDMI output
●Built-in Gyro (in development)
●AV in
●Built-in Bluetooth Wi-Fi module (in development)
