| IPad Pro 12.9 5th Gen Touch Screen Not Working | |
| Device | IPad Pro 12.9 5th Gen |
| Needs equipment | Multimeter, Soldering Iron |
Fixing a problem where the iPad turns on but the touch screen does not respond to any input.
- Non working touch
Check for shorts on the capacitors near the two BCM15957A0 touch controllers above the lower display connectors. Often there will be a failed capacitor causing no touch.
