| MacBook Pro A1990 No backlight repair | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
Identifying and solving backlight issues on the A1990 MacBook, as well as similar boards from 2016-2020. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
- Bad screen - if backlight voltage is 49-55v, could be bad screen, but not 100% of the time. Could be data communication issues.
- Corrosion on current sense vias/traces for backlight to U8400 LP8548
