| IPad Pro 12.9 5th Gen Touch Screen Not Working | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
iPad turns on but the touch screen does not respond to any input.
- Symptom 1 (Figure 1)
- Symptom 2
Check for shorts on the capacitors near the two BCM15957A0 touch controllers above the lower display connectors. Often there will be a failed capacitor causing no touch.
