| MacBook Pro A1990 Battery not recognized repair | |
| Device | MacBook Pro A1990 |
| Type | Soldering, Micro-Soldering"Micro-Soldering" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property., Part replacement |
MacBook A1990 not recognizing the connected battery
- MacBook not turning on.
- Battery not recognized/charging
- First, try a known good battery.
- If it doesn't work, check the battery cable going to the board.
- Sometimes there is corrosion here, sometimes the customer tore the bar on the connector off the connector.
- In some rare cases the SMC still is a factor in battery recognition on this board.
