MacBook Pro A1990 Battery not recognized repair
Revision as of 16:07, 11 October 2023 by ASRepairs (talk | contribs) (Created page with "{{stub}} {{Repair Guide |Device= |Affects parts= |Needs equipment= |Type= |Difficulty= }} ==Problem description== MacBook A1990 not recognizing the connected battery thumb|Example image (Figure 1) -- No image yet. Help expand this page by uploading it! ==Symptoms== *MacBook not turning on. *Battery not recognized/charging ==Solution== * First, '''try a known good battery.''' ** If it doesn't work, check the battery cable going to the boa...")
Device
Affects part(s)
Needs equipment
Difficulty
Type
  • MacBook not turning on.
  • Battery not recognized/charging
  • First, try a known good battery.
    • If it doesn't work, check the battery cable going to the board.
      • Sometimes there is corrosion here, sometimes the customer tore the bar on the connector off the connector.
  • In some rare cases the SMC still is a factor in battery recognition on this board.
