| Thinkpad T490 Bios Password Removal | |
| Device | Thinkpad T490 |
| Affects part(s) | MEC1633 |
| Needs equipment | Soldering Iron; Glasgow Interface Explorer (or other EC programmer), Screwdrivers, Spudgers |
What you need
- Take off the bottom cover
- Disconnect the CMOS battery
- Remove the trackpad screws
- Disconnect the charger
- Initialize the EEPROM
- Assign UUID
- Set system identification
EEPROM Offsets
1. Determine the JTAG pinout
Glasgow will do this automatically for you, just run:
$ glasgow run jtag-pinout -V 3.3 --pins-jtag 0:15
This command will print something like this on its last line:
The following commands show example values for the --pin-* arguments. Instead of those examples copy-paste the values the first command returns for you.
2a. Read/Modify/Write the EEPROM
Edit dump.bin with hex editor
2b. Erase the EEPROM
This is useful if you cannot figure out the offsets where the password is stored or if you don't want to bother with multiple cycles of making a change, writing it to eeprom, and power cycling the laptop in a half-assembled state, to see if the password removal was successful.
- It supports reading/writing the EEPROM only, without erasing the firmware
Not tested by the authors of this page, but the following information was found online, please take the following with a grain of salt, we cannot confirm any of this:
- Vertyanov JIG ver. 8.1.7897.157 supports reading and writing the eeprom area only. Select a MEC16xx variant from the dropdown that has EEPROM. Demo video shows the user selecting MEC1653, then select EEPROM only from the second dropdown.[1]
- RT809F with software version 20220830 may be able to read/write the full 256KiB of flash memory, when selecting MEC1633_256K in the "Partnumber" list. No evidence seen on this video for support of EEPROM-only access, so if it works, it will only be able to do the emergency erase method.[2]
