| Thinkpad T490 Bios Password Removal | |
| Device | Thinkpad T490 |
| Affects part(s) | MEC1633 |
| Needs equipment | Soldering Iron; Glasgow Interface Explorer (or other EC programmer), Screwdrivers, Spudgers |
What you need
- Take off the bottom cover
- Disconnect the CMOS battery
- Remove the trackpad screws
- Solder wires to the JTAG pins. See Figure 5 for the pinout. Note that with Glasgow Interface Explorer you don't need to worry about the exact pinout, because the tool can auto-detect it for you, just make sure you get the GND pin right, and that you solder a wire to all other pins except for pin 6.
- Disconnect the charger
- Initialize the EEPROM
- Assign UUID
- Set system identification
EEPROM Offsets
1. Determine the JTAG pinout
Glasgow will do this automatically for you, just run:
$ glasgow run jtag-pinout -V 3.3 --pins-jtag 0:15
This command will print something like this on its last line:
The following commands show example values for the --pin-* arguments. Instead of those examples copy-paste the values the first command returns for you.
2a. Read/Modify/Write the EEPROM
Edit dump.bin with hex editor
2b. Erase the EEPROM
This is useful if you cannot figure out the offsets where the password is stored or if you don't want to bother with multiple cycles of making a change, writing it to eeprom, and power cycling the laptop in a half-assembled state, to see if the password removal was successful.
- It supports reading/writing the EEPROM only, without erasing the firmware
