| Thinkpad T490 Bios Password Removal | |
| Device | Thinkpad T490 |
| Affects part(s) | MEC1633 |
| Needs equipment | Soldering Iron; Glasgow Interface Explorer (or other EC programmer), Screwdrivers, Spudgers |
What you need
- Take off the bottom cover
- Disconnect the CMOS battery
- Remove the trackpad screws
- Solder wires to the JTAG pins. See Figure 5 for the pinout. Note that with Glasgow Interface Explorer you don't need to worry about the exact pinout, because the tool can auto-detect it for you, just make sure you get the GND pin right, and that you solder a wire to all other pins except for pin 6.
- Disconnect the charger
- If you have cleared the EEPROM completely, then you will have to restore the laptop serial numbers. In this case use ThinkPad Serial Number Update Utility.
- Initialize the EEPROM
- Assign UUID
- Set system identification
EEPROM Offsets
- 256KiB of embedded flash
- 2KiB of EEPROM
So far passwords have only been observed to be stored in the EEPROM memory. The EC has some protection features that allow:
- Blocking reading/writing of the "Boot Block", which is the first 4KiB of embedded flash
- Blocking reading/writing of the "Data Block", which is the last 4KiB of emvedded flash
- Blocking reading/writing of the EEPROM, using a 31-bit passwords
- Completely disabling JTAG
So far none of these security features have been observed to be enabled
