Thinkpad T490 Bios Password Removal | |
Device | Thinkpad T490 |
Affects part(s) | MEC1633 |
Needs equipment | Soldering Iron; Glasgow Interface Explorer (or other EC programmer), Screwdrivers, Spudgers |
Type | Soldering, Software |
What you need
- Take off the bottom cover
- Disconnect the CMOS battery
- Remove the trackpad screws
- Solder wires to the JTAG pins. See Figure 5 for the pinout. Note that with Glasgow Interface Explorer you don't need to worry about the exact pinout, because the tool can auto-detect it for you, just make sure you get the GND pin right, and that you solder a wire to all other pins except for pin 6.
- Use your EC programmer tool to manipulate the EEPROM, to remove the password. (See following section for details)
- Disconnect the charger
- Restore the TRST resistor to its pull-down configuration, and remove the jtag wires
- If you have cleared the EEPROM completely, then you will have to restore the laptop serial numbers. In this case use ThinkPad Serial Number Update Utility.
- Initialize the EEPROM
- Assign UUID
- Set system identification
