Epson ELPDC21 | |
Manufacturer | Epson |
Code name | H757MA_R2 2176136 |
Release date | |
Device type | Camera |
Type | Difficulty | |
Epson ELPDC21 Debugging UART | Troubleshooting/Diagnostics | 3. Hard |
The device - seen from above.
Main board - top side
Main board - bottom side
PCB in camera head
Voltages measured on a working unit
Measured voltages - Zoomed in on two smaller regulators
Uart Signals
SPI communication pins between main CPU and Thine ISP chip
The power button signal
Main CPU (SoC) reset signal
Under the THP7321
Bottom of the THP7312
I2C SCL and SDA lines
Component RefDes | Voltage | Type |
C2008/C2011/L2000 | 5.15V | Switching |
C1911/C1912/L1903 | 3.3V | Switching |
C2012/L2001 | 1.2V | Switching |
C1905/L1901 | 1.35V | Switching |
C1910/C1922/L1902 | 1.42V | Switching |
C1904/L1900 | 3.0V | Switching |
C2003/IC2000 | 3.3V | Linear |
C2009/IC2003 | 1.8V | Linear |
C1804/IC1800 | 3.33V | Linear, Always On |
Partial BOM
Component RefDes | Marking | Name | Comment |
IC2002, IC1903, IC2004, IC1901, IC1902, IC1900 | QTZ | TPS62140RGTR/TPS62140RGTT | Step-down converter |
IC2000 | NR1 | TLV70033DSER/TLV70033DSET | 3.3V linear regulator |
IC2003 | NK1 | TLV70018DSER/TLV70018DSET | 1.8V linear regulator |
IC1800 | LPBG | LP2981-33 | 3.3V linear regulator |
IC1600, IC1603 | G8Y | S-80928CNNB-G8YT2x | 2.8V Voltage detector with delay (IC1600 resets the main CPU, IC1603 resets the smaller microcontroller IC1000) |
IC1000 | C17W04F10J | Epson S1C17W04 | 16-bit Microcontroller, Always On |
IC900 | Hynix H27U4G8_6F2D / H27S4G8_6F2D | Nand Flash | |
IC1300 | THP7312 | THine THP7312 | ISP chip |
IC1 | MCIMX6D5EYM10AD | IMX6DQCEC | Main CPU: i.MX 6Dual/6Quad Applications Processors for Consumer Products |
C205 | 220nF | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
C272 | 100nF | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
R209 | 9.1 ohm | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
R353 | 0 ohm link | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. |
Useful Signals
Component | Pin # | Name | Comment |
CN1600 | 7 | UART_TX | (TX from the board's perspective, runs at 460800 bps) |
CN1600 | 9 | UART_RX | |
CN1300 | 10 | I2C_SCL | I2C line is shared by devices on the motherboard, but also goes to the camera head |
CN1300 | 11 | I2C_SDA | |
IC1600 | 4 | Reset of the main CPU | Short this to ground to cause a main CPU reboot. (this is an open drain output of the voltage detector, so it's okay to short to ground) |
CN2001/CN1000* | 2 | Power Button | Short this to ground to prompt the board to boot even when the flex cable to the interface board is not connected |
