| Epson ELPDC21 Not turning on, led blinking | |
| Device | Epson ELPDC21 |
| Affects part(s) | Connectors |
| Needs equipment | Screwdrivers |
| Difficulty | ◉◉◌◌ Medium |
| Type | Teardown |
- Symptom 1 (Figure 1)
- Symptom 2
