| Epson ELPDC21 | |
| Manufacturer | Epson |
| Release date | |
| Device type | Camera |
The device - seen from above.
Main board - top side
Main board - bottom side
Voltages measured on a working unit
Measured voltages - Zoomed in on two smaller regulators
Uart Signals
SPI communication pins between main CPU and Thine ISP chip
The power button signal
Main CPU (SoC) reset signal
Partial BOM
Useful Signals
| CN1600 | 9 | UART_RX | |
| CN1300 | 11 | I2C_SDA | |
| CN2001/CN1000* | 2 | Power Button | Short this to ground to prompt the board to boot even when the flex cable to the interface board is not connected |
