Epson ELPDC21 | |
Manufacturer | Epson |
Code name | H757MA_R2 2176136 |
Release date | |
Device type | Camera |
Type | Difficulty | |
Epson ELPDC21 Debugging UART | Troubleshooting/Diagnostics | 3. Hard |
Component RefDes | Voltage | Type |
C2008/C2011/L2000 | 5.15V | Switching |
C1911/C1912/L1903 | 3.3V | Switching |
C2012/L2001 | 1.2V | Switching |
C1905/L1901 | 1.35V | Switching |
C1910/C1922/L1902 | 1.42V | Switching |
C1904/L1900 | 3.0V | Switching |
C2003/IC2000 | 3.3V | Linear |
C2009/IC2003 | 1.8V | Linear |
C1804/IC1800 | 3.33V | Linear, Always On |
Partial BOM
Component RefDes | Marking | Name | Comment |
IC2002, IC1903, IC2004, IC1901, IC1902, IC1900 | QTZ | TPS62140RGTR/TPS62140RGTT | Step-down converter |
IC2000 | NR1 | TLV70033DSER/TLV70033DSET | 3.3V linear regulator |
IC2003 | NK1 | TLV70018DSER/TLV70018DSET | 1.8V linear regulator |
IC1800 | LPBG | LP2981-33 | 3.3V linear regulator |
IC1600, IC1603 | G8Y | S-80928CNNB-G8YT2x | 2.8V Voltage detector with delay (IC1600 resets the main CPU, IC1603 resets the smaller microcontroller IC1000) |
IC1000 | C17W04F10J | Epson S1C17W04 | 16-bit Microcontroller, Always On |
IC900 | Hynix H27U4G8_6F2D / H27S4G8_6F2D | Nand Flash | |
IC1300 | THP7312 | THine THP7312 | ISP chip |
IC1 | MCIMX6D5EYM10AD | IMX6DQCEC | Main CPU: i.MX 6Dual/6Quad Applications Processors for Consumer Products |
C205 | 220nF | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
C272 | 100nF | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
R209 | 9.1 ohm | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. | |
R353 | 0 ohm link | Author replaced mechanically damaged component, not sure about correctness of this measurement, but product worked with replacement. |
Useful Signals
Component | Pin # | Name | Comment |
CN1600 | 7 | UART_TX | (TX from the board's perspective, runs at 460800 bps) |
CN1600 | 9 | UART_RX | |
CN1300 | 10 | I2C_SCL | I2C line is shared by devices on the motherboard, but also goes to the camera head |
CN1300 | 11 | I2C_SDA | |
IC1600 | 4 | Reset of the main CPU | Short this to ground to cause a main CPU reboot. (this is an open drain output of the voltage detector, so it's okay to short to ground) |
CN2001 | 2 | Power Button | Short this to ground to prompt the board to boot even when the flex cable to the interface board is not connected |
