| Epson ELPDC21 | |
| Manufacturer | Epson |
| Release date | |
| Device type | Camera |
The device - seen from above.
Main board - top side
Main board - bottom side
Voltages measured on a working unit
Measured voltages - Zoomed in on two smaller regulators
Partial BOM
Useful Signals
| CN1600 | 8 | UART_RX | |
| CN1300 | 11 | I2C_SDA | |
| CN2001 | 2 | Power Button | Short this to ground to prompt the board to boot even when the flex cable to the interface board is not connected |
