| MacBook Pro A2159 Not charging after MacOS update repair | |
| Device | MacBook Pro A2159 |
| Affects part(s) | Software |
| Needs equipment | None |
| Type | Software |
After MacOS upgrade, all 4 USB ports dead. No ability to charge.
- Can't charge MacBook
Try power button reset. Then try SMC reset. If neither has effect, disconnect battery or discharge battery to 0.
The SMC update during a MacOS upgrade may silently fail leaving no power access to the USB ports. This happened to the author after a Catalina 10.5.7 update. Multiple power button resets and SMC resets may not work. Genius bar is baffled. Disconnecting/discharging the battery to 0 allowed the SMC to fully reset.
