| MacBook Pro A2159 No backlight on display repair | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
Identifying and solving backlight issues on the 820-01598 logic board, as well as similar boards from 2016-2020. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
- C8468 or adjacent capacitors in the series is an appropriate area to measure, since it does not require removal of the system board.
Check U8400 and its circuit
Occasionally, with 820-01598 boards with failed U7710/U8110 (GAY/GAV marked ICs) backlight failure will proceed the no power fault. In these cases, U8400 is almost always the cause of the problem.
