MacBook Air A2179 No camera detected repair | |
Device | MacBook Air A2179 |
Affects part(s) | Motherboard, Camera, Display assembly |
Addressing issues with a MacBook (820-01958) not detecting the camera.
- Camera not detected
- Possible burned or exploded L8570 filter on TCON board
Check L8570 Continuity
- Use a multimeter in continuity mode to check L8570 (Figure 1).
- If L8570 is blown or burned, proceed to the "L8570 blown or visibly burned repair steps" below.
Test with Known Good Display
- Make sure to check L8570 before diagnosing the display issue.
- If camera works with a known good test display, replace the display assembly.
L8570 Blown or Visibly Burned
- Understand that L8570 failure indicates a catastrophic short within the TCON board of the display or a melted/corroded display cable/connector.
- Repair L8570 only after addressing the display issue, as L8570 might fail again if the display issue persists.
- When replacing L8570, address corresponding pad and trace damage.
- The closest recommended jumper point for the input side of the filter (PP5v_G3S) is CC775/CC774 if the traces and vias for PP5v_G3S are not damaged in that area. If damage is seen on and around CC775/CC774, use L6703 as a jumper point. Ensure you have conductivity between PP5v_G3S and CC775/CC774 if you are using those capacitors as a jumper point.
- After replacing L8570 and addressing trace issues, replace the display assembly or repair it by replacing damaged cables/connectors.
No Camera Function, L8570 Normal
- If no camera function after firmware revive, and other causes are ruled out, U8595 might be faulty, or there could be trace/resistor issues between the camera connector/U8595 or between U8595 and the T2 chip.
