| MacBook Pro A2289 No camera detected repair | |
| Device | |
| Affects part(s) | |
| Needs equipment | |
| Difficulty | |
| Type | |
Addressing issues with MacBook Pro 820-01987 not detecting the camera.
- Camera not detected
- Possible burned or exploded L8504 filter on TCON board
Check L8504 Continuity
- Use a multimeter in continuity mode to check L8504 (Figure 1).
- If L8504 is blown or burned, proceed to the "L8504 blown or visibly burned repair steps" below.
Test with Known Good Display
- Make sure to check L8504 before diagnosing the display issue.
If camera works with a known good test display, replace the display assembly.
L8504 Blown or Visibly Burned
- Understand that L8504 failure indicates a catastrophic short within the TCON board of the display or a melted/corroded display cable/connector.
- Repair L8504 only after addressing the display issue, as L8504 might fail again if the display issue persists.
- When replacing L8504, address corresponding pad and trace damage.
- Connect jumper wire from the input side of the filter (PP5v_G3S) to R5610 (Figure 2) or a suitable point.
- After replacing L8504 and addressing trace issues, replace the display assembly or repair it by replacing damaged cables/connectors.
No Camera Function, L8504 Normal
- If no camera function after firmware revive, and other causes are ruled out, U8504 might be faulty, or there could be trace/resistor issues between the camera connector/U8504 or between U8504 and the T2 chip.
