| How To Fix an iPhone 15 That Randomly Restarts | |
| Device | iPhone 15, iPhone 15 Plus |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 15 and iPhone 15 Plus to randomly restart every few minutes. For the iPhone 15 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 15 series are:
- Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
- Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
- After a hard drop, the iPhone will restart every 3 minutes.
If you see:
- 0x200000 - it's the Wireless Charging Flex (Back Glass)
- Make sure it's plugged in & the flex is not torn
- Check that there's no liquid damaged, or that it's defective
- Could be a sandwich issue
- 0x80000 - it's the Charging Port Flex
- 0x100000 - it's the Proximity Flex Cable
- Bad or damaged flex
