| Type | Component |
| Device(s) | Resistors |
What is a Resistor?
Voltage divider
A voltage divider is an electrical circuit that divides a higher input voltage into a lower output voltage using two or more resistors in series.
The output voltage of a resistive divider is determined by the ratio of the resistance values in the circuit like so:
Uses:
- Reference Voltage: Voltage dividers can be used to create stable reference voltages for sensor calibration, analog signal processing, and feedback in voltage converters; provided they are powered from a stable voltage source, as any deviations in the source voltage will likewise appear in the scaled down output.
- Voltage Monitoring: In some battery-powered devices, voltage dividers are used to monitor the battery voltage to determine its state of charge. This is a similar application to the aforementioned voltage scaling for measurements.
- Volume control in analog audio: for this, a potentiometer is used, to have an adjustable ratio in the divider and thus making the volume user-adjustable.
- Et Cetera.
Resistor sensors
Pull-up / Pull-down
Current measurement
Resistor Packages and Value Codes
Axial Through-Hole Resistor
Surface Mount Device (SMD)
These resistors are usually small in size and have no wire leads, instead their metallized ends get soldered directly to pads on a circuit board.
Appearance wise, they are small rectangular and thin wafers, usually a white ceramic substrate with black paint on the top side, and a three or four digit numerical code denoting the value, where the last digit is the multiplier or "number of zeroes" (for example, 221 on a resistor means 220 ohms).
Another notation has the value written as a number with decimals, where the decimal point is replaced with a letter that represents the multiplier (R for 1, K for 1000, M for 100000), for example, "4k7" denotes a 4700 Ohm resistor. This notation is also occasionally used in power resistors of the through-hole axial and ceramic types.
Wire Wound Resistor
One of the oldest types of resistors and still widely used for power applications. They are made of a length of metal wire coiled around a rigid insulating core for support.
The wire is usually Nichrome for its high temperature resistance, and the cores are usually made of some form of ceramic, mica or rarely glass for the same reason. Some antique resistors contained asbestos in the core.
The wire coil is often encased in a porcelain shell and potted with cement.
Other variants have the core covered in glaze, encasing the windings. Sometimes the glaze would leave a strip uncoated along the length of the resistor, in order for a clamp to be attached and make contact at a desirable location, making a tapped resistor.
Yet some other examples leave the windings uncovered, usually in older high power resistors and rheostats.
Their most common use is as power resistors, and as heating elements. Some high precision resistors for instruments are also wire wound, sometimes with two different thicknesses of wire to trim the value to spec. These sometimes lack the construction meant to withstand high temperatures.
Because of their construction, they can have substantial parasitic inductance, making them unsuitable for high frequency applications. They can also introduce RF noise to a circuit, acting as loop antennas.
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Testing a Resistor
Replacement Considerations
