Resistors - Repair Basics
Type Component
Device(s) Resistors
Difficulty ◉◌◌◌ Easy
What is a Resistor?
Resistor symbols commonly found in schematics (Figure 1)
Voltage divider
A voltage divider is an electrical circuit that divides a higher input voltage into a lower output voltage using two or more resistors in series.
The output voltage of a resistive divider is determined by the ratio of the resistance values in the circuit like so:
Voltage divider circuit (Figure 2)
Uses:
  • Reference Voltage: Voltage dividers can be used to create stable reference voltages for sensor calibration, analog signal processing, and feedback in voltage converters; provided they are powered from a stable voltage source, as any deviations in the source voltage will likewise appear in the scaled down output.
  • Voltage Monitoring: In some battery-powered devices, voltage dividers are used to monitor the battery voltage to determine its state of charge. This is a similar application to the aforementioned voltage scaling for measurements.
  • Volume control in analog audio: for this, a potentiometer is used, to have an adjustable ratio in the divider and thus making the volume user-adjustable.
  • Et Cetera.
Resistor sensors
Pull-up / Pull-down
Current measurement
Example and further reading
Resistor Packages and Value Codes
Axial Through-Hole Resistor
Surface Mount Device (SMD)
These resistors are usually small in size and have no wire leads, instead their metallized ends get soldered directly to pads on a circuit board.
Appearance wise, they are small rectangular and thin wafers, usually a white ceramic substrate with black paint on the top side, and a three or four digit numerical code denoting the value.
Fixed value resistors
Different types of resistors (Figure 3)
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Measuring a Resistor (Figure 4)
Testing a Resistor
Wirewound Resistor (Figure 5)
Replacement Considerations
