| Type | Component |
| Device(s) | Resistors |
What is a Resistor?
Voltage divider
They are also used for scaling down high amplitude signals for measurements, being implemented either internally to an instrument or added externally for a specific task.
Uses:
- And much more.
Resistor sensors
Pull-up / Pull-down
Current measurement
Resistor Packages and Value Codes
Axial Through-Hole Resistor
Surface Mount Device (SMD)
These resistors are usually small in size and have no wire leads, instead their metallized ends get soldered directly to pads on a circuit board.
Appearance wise, they are small rectangular and thin wafers, usually a white ceramic substrate with black paint on the top side, and a three or four digit numerical code denoting the value.
Fixed value resistors
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Testing a Resistor
Replacement Considerations
