Resistors - Repair Basics
Revision as of 13:35, 23 February 2026 by Phonograph Steve (talk | contribs) (→‎Resistor sensors)
Type Component
Device(s) Resistors
Difficulty ◉◌◌◌ Easy
What is a Resistor?
Resistor symbols commonly found in schematics (Figure 1)
Voltage divider
They are also used for scaling down high amplitude signals for measurements, being implemented either internally to an instrument or added externally for a specific task.
Voltage divider circuit (Figure 2)
Uses:
  • Reference Voltage: Voltage dividers can be used to create stable reference voltages for sensor calibration, analog signal processing, and feedback in voltage converters.
  • Voltage Monitoring: In some battery-powered devices, voltage dividers are used to monitor the battery voltage to determine its state of charge.
  • And much more.
Resistor sensors
Pull-up / Pull-down
Current measurement
Example and further reading
Fixed value resistors
Different types of resistors (Figure 3)
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Measuring a Resistor (Figure 4)
Testing a Resistor
Wirewound Resistor (Figure 5)
Replacement Considerations
