| Sony Dualshock 4 Not Charging | |
| Device | Sony Dualshock 4 |
| Affects part(s) | |
| Needs equipment | |
| Type | |
The Controller does not charge
- Device does not charge
- Replace battery (less likely)
- Check for short on battery connector, check current consumption from battery connector using a bench PSU(in case a power rail that turns on with the device is short), if a high current is being taken check voltages and for shorts on caps nearby PMIC, and PMIC itself. If a short is found, remove suspected capacitor, if the short persists repeat for all parts on that power rail ending with the PMIC until it is gone.
- Replace charging port board (more likely)
*This guide was imported from the old wiki.
