Sony Dualshock 4 Not Charging
Revision as of 00:16, 9 December 2025 by Tiago199988 (talk | contribs)
Device Sony DualShock 4
Affects part(s)
Needs equipment
Difficulty ◉◌◌◌ Easy
Type
The Controller does not charge
  • Device does not charge
  • Replace battery (less likely)
  • Check for short on battery connector, check current consumption from battery connector using a bench PSU(in case a power rail that turns on with the device is short), if a high current is being taken check voltages and for shorts on caps nearby PMIC, and PMIC itself. If a short is found, remove suspected capacitor, if the short persists repeat for all parts on that power rail ending with the PMIC until it is gone.
    • Replace charging port board (more likely)
*This guide was imported from the old wiki.
