| How To Fix an iPhone 15 Pro That Randomly Restarts | |
| Device | iPhone 15 Pro, iPhone 15 Pro Max |
| Needs equipment | Screwdrivers, known good parts, spudger |
| Type | Part replacement |
There are many reasons that could cause an iPhone 15 Pro and iPhone 15 Pro Max to randomly restart every few minutes. For the iPhone 15 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
- Back Glass/Wireless Charging Flex - This is the flex that wraps around the logic board & controls the power button.
- Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
- After a hard drop, the iPhone will restart every 3 minutes.
If you see:
- 0x300000 - It's the Charging Port Flex
- Diode mode the FPC connectors for any fault
- 0x400000 - It's the Wireless Charging Flex on the Back Glass
- 0x700000 - It's 2 problems: Charging Port Flex and Wireless Charging Flex
- Make sure both flex cables are plugged in
- 0xa1 - It's a battery data issue.
- Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
- Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
- Diode mode the battery connector pins & compare them to known good board
- Test with a known good battery
- Replace the battery connector
- Bad or damaged flex
Please note: You MUST have the required flex cables, (Charging port flex, Wireless Charging Flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
