How To Repair PS4 Overheating
Revision as of 05:24, 30 November 2025 by IamMyron07 (talk | contribs) (→‎Solution)
Device Playstation 4, Playstation 4 Pro, Playstation 4 Slim
Affects part(s) Cooling Fan
Needs equipment Screwdrivers, Prying Tools
Difficulty ◉◉◌◌ Medium
Type Part Replacement"Part Replacement" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property.
PS4 (all variants – Fat / Slim / Pro) overheats, becomes extremely loud, or shuts down with the message:
“The PS4 is too hot. Turn off the PS4 and wait until the temperature goes down.”
Most common causes:
  • Dust-clogged heatsink & vents
  • Fan not spinning (failed fan or power rail issue)
  • Dry or worn-out thermal paste
  • Obstructed airflow due to pet hair, smoke residues, or environmental buildup
  • Incorrect reassembly after previous repair
PS4 Overheating Warning
Playstation 4 Cooling FAN
  • Loud jet-engine noise before shutdown
  • Immediate shutdown after launching a game
  • Overheating warning
  • No fan spin on boot
  • Random frame drops or lag (thermal throttling)
  • Hot bottom shell or rear grill
  • Fan oscillates or starts/ stops suddenly
Playstation 4 Dry Thermal Paste
Playstation 4 Heatsink
1. External Inspection
  • Check air vents for dust buildup
  • Confirm console placement (not inside a closed cabinet)
  • Check for pet hair, cigarette tar, debris
2. Boot Test
  • Power on the PS4 while watching the fan:
    • Spins at boot = Fan OK
    • Clicks or hesitates/No spin = Worn bearings or mechanical fan fault
3. Thermal Paste Check
If PS4 has never been serviced:
  • Thermal paste is usually dry
  • Dust likely packed inside heatsink fins
4. Heatsink Airflow Check
Common issue: packed dust wall between fan and heatsink.
1. Disassembly
(Varies by PS4 model)
  • Remove top cover
  • Remove power supply (PS4 Fat)
  • Disconnect fan connector
  • Remove motherboard
  • Extract entire cooling assembly
2. Cleaning (Critical Step)
Fan Cleaning
  • Use compressed air + soft brush
  • Spin fan manually to verify smooth rotation
  • If grinding noise → Replace fan
Vents & Shell
  • Clean rear vents and side inlets thoroughly
  • Remove dust mats (large clumps)
Heatsink Cleaning
  • Remove old dust “blanket” from heatsink fins
  • Flush with air from both directions
3. Thermal Paste Replacement
  • Remove old paste from APU and heatsink using isopropyl alcohol
  • Apply high-quality thermal paste (Arctic MX-4 / Arctic Silver / Noctua NT-H1)
  • Ensure full flat contact with even pressure
4. Reassemble the Cooling System
  • Reinstall heatsink securely
  • Ensure all screws (especially pressure screws) are tightened in X pattern
  • Reconnect fan carefully
  • Reassemble the rest of the console
5. Replace Fan (If Dead)
When to replace:
  • No spin at boot
  • Weak or intermittent spin
  • Noise from bearings
  • Burnt smell or discoloration
Part requirements:
  • Model-specific fan (PS4 Fat, Slim, Pro each use different connectors)
Replace fan → test again.
Verification
After reassembly:
  • Boot console → fan should spin immediately
  • Run a game for 20–30 minutes
  • No overheating message
  • Fan ramps gradually, not instantly
  • Rear exhaust warm (normal)
  • System stable under stress
