| PS5 Standby Boot Sequence & Consumption Analysis | |
| Device(s) | PlayStation 5, PlayStation 5 Pro, PlayStation 5 Slim |
🔌 PS5 Resting Power Consumption Using DCPS
Checking the resting power draw with a DCPS helps determine the console’s current health.
A DCPS (bench power supply) should be set to 12V / 2A and used to inject power into the 12V rail of the PS5.
Below is what different resting consumption levels may indicate, but first—here’s how to connect it properly.
📎 How to Connect the Power Supply
- Set voltage to 12V
- Set amperage to 2A
- Turn OFF the power supply
- Attach clips to the board prongs
- Turn ON the power supply and monitor consumption for 10–15 seconds
📊 What Healthy Readings Look Like
- Amperage climbs to ~0.321A for a few seconds
- Then drops to ~0.007A
This suggests the console is likely in good condition.
Data sourced from FixMyApp Research ✔️
| First Stage | Second Stage | Potential Cause |
| +- 321 mA | +- 7 – 10 mA | WORKING / GOOD |
| +- 0.0 mA | +- 0.0 mA | Check BIOS and fuses, +12V power supply, Check for short on the +12V input |
| +- 0.015 mA | +- 0.015 mA | Check for shorts near Soutbridge IC |
| +- 5 mA | +- 5 mA | Check for shorts near HDMI encoder IC |
| +- 7 mA | +- 27 mA | Check for shorts near Soutbridge IC |
| +- 7 mA | +- 7 mA | When console get’s standby power if it is stuck at 7mA. Check the voltages of Dialog ic and frequency of the 25Mhz clock and the
32Khz clock of the Southbridge IC. If that is working, try to see if the Southbridge is accessing the BIOS IC. Flash firmware / Replace the BIOS IC, Southbridge IC |
| +- 7 mA (boot loop) | +- 12 mA | Check for short on the 1.1V power rail |
