| Top Board Only Sandwich Boards
Will boot?
Touch?
Restart Issues?
Temp Warning Issue?
Notes
| iPhone X (Intel)
No
No
N/A
N/A
- Top Board Only will boot to DFU Mode. You can flash & retain user data on 3u Tools to get it to boot.
- Or you can bypass dfu mode with top board only by running a jumper from pin S41 to S48
- Requires Charging Port to prevent top board only from restarting (Mic1)
| iPhone X (Qualcomm)
Yes
No
No
No
- Must use Socket Jig to get touch working
- Requires Charging Port to prevent top board only from restarting (Prs0/Mic1)
| iPhone XS, XS Max
Yes
No
No
No
| iPhone 11
Yes
Yes
Yes
No
- Since mic 2 connects to the main board via the sandwich, it requires the bottom board to avoid 3 min restarts.
| iPhone 11 Pro, 11 Pro Max
Yes
Yes
No
No
- Can get data with top board only. Just make sure to plug in a power button flex (Mic2) and charging port flex (Prs0/Mic1)
| iPhone 12, 12 Pro, 12 Mini
Yes
Yes
No
No
- Can get data with top board only. Just make sure to plug in a charging port flex (Prs0/Mic1)
- If you want brightness to work, plug in the ear speaker flex. If ALS sensor is not detected, screen will stay dim
| iPhone 12 Pro Max
Yes
Yes
No
Yes
- With top board only, the phone will boot to a false positive overheating temp warning, even if it's cold.
- You can bypass the temp warning by running a 10k Ohm resistor to ground on these 2 lines: a. Pin 487 - NTC_RADIO_BB_SE b. Pin 489 - NTC_RADIO_PA_SE
- You can also just plug in a known good bottom board using an iSocket jig to get data
- Make sure to plug in a charging port flex (Prs0/Mic1) to prevent 3 min restart
| iPhone 13 Mini
Yes
Yes
Yes
No
- This model requires the bottom board to prevent 3 min restart (0x400)
- The issue is, the top board must communicate with the gyroscope in order to function correctly and not restart every 3 minutes. Rebuilding pads 207, 208, 502, 503, 504, 527, 528 is all that is needed from the bottom board.
- Requires proximity flex to prevent board only from restarting (0x1000)
- Requires charging port flex to prevent board from restarting (0x800)
| iPhone 13, 13 Pro, 13 Pro Max
Yes
Yes
No
No
- You can get data with just top board only.
| iPhone 14, 14 Plus
No
N/A
N/A
N/A
- Requires both layers connected for the board to boot
| iPhone 14 Pro, 14 Pro Max
Yes
Yes
Yes
No
- This model requires the bottom board to prevent 3 min restart.
- Unknown what is needed from the bottom board to prevent the 3 min restart. (0x20000)
- Requires proximity flex to prevent board only from restarting (0x80000 )
- Requires charging port flex to prevent board from restarting (0x40000 )
- Requires the power button flex to prevent board from restarting (0x10000)
| iPhone 15, 15 Plus
No
N/A
N/A
N/A
| iPhone 15 Pro, 15 Pro Max
Yes
Yes
Yes
No
TBD...
