MacBook Air A2337 No sound from speakers repair | |
Device | MacBook Air A2337 |
Needs equipment | |
Issue with MacBook Air A2337 not playing sound from speakers.
- No sound from speakers
- Not a software issue
Check SPKRAMP_1V8_RESET_L
You should measure 1.8V, if you measure 0 volts, proceed to the repair steps below.
No or low SPKRAMP_1V8_RESET_L
- UR900 is most likely the issue.
- Run wire from CR901 pin 2 that has 1.8 volts to pin 1 of CE904 this will force SPKRAMP_1V8_RESET_L high and allow speakers to power up.
Note: As of writing I could not find UR900 (SN74AVC4T234) for purchase it is recommended you replace UR900 but this workaround works fine so far assuming UR900 is being told to turn on and SPKRAMP_RESET_L is present.
