Apple ACE2 Controllers
Revision as of 07:56, 6 October 2025 by David.Lecomte (talk | contribs)
Manufacturer Apple
Code name ACE2
Release date 2019
Device type Laptop
I. Function
  • Port 2, carried by pins B7, A6 and C8, respectively for SDA, SCL and IRQ. This interface is controlled by the SMC, which is part of the T2 SOC or Apple Silicon SOC, depending on the architecture.
II.1 Determination of type
II.1.2 ACE2 purchased as new
II.1.3 ACE2 of unknown origin
II.2 I2C addresses decoding
Resistor value ADDR
000
38.3kΩ 001
84.5kΩ 010
140kΩ 011
205kΩ 100
280kΩ 101
374k 110
Infinite (floating) 111
Port 1 address: 111ADDR
  • ADDR (UPC5_I2C_ADDR) floating, since this pin goes to R5650 which is not present on the board. This sets ADDR = 111.
  • The new ACE2 is OTP-ed with the same addresses as the one it is replacing. Then the USB-C PD system will work right away.
  • The new ACE2 is OTP-ed with another address than the one it is replacing. This address will either conflict with an already present ACE2, or it won't correspond to the I2C map. Either way, the whole USB-C system is down.
  • The new ACE2 is vanilla. It will acquire the address imposed by the configuration resistors, which conflicts with another ACE2's address, and the whole USB-C system is down.
  • The new ACE2 is OTP-ed with addresses 0x3A and 0x3A. Then the board will work right away.
  • The new ACE2 is OTP-ed as 0x3B and 0x3B, or 0x3C and 0x3C. Then it will conflict with UG400 which already has addresses 0x3B; or it doesn't correspond to the I2C map, which doesn't include 0x3C. Either way, the whole USB-C system is kaput.
  • The new ACE2 is vanilla. It will acquire addresses 0x3F and 0x2F, conflicting with UF500 on the AP_I2C0 bus. USB-C system is down.
AP_I2C0
SMC_I2C1
UF400
UPC0
UF500
UPC1
UG400
UPC2
U5500
UPC5
Port 1 0x38
111000b
0x3F
111111b
0x3B
111011b
0x3A
111010b
Port 2 0x38
111000b
0x3F
111111b
0x3B
111011b
0x3A
111010b
  • No PPBUS_AON.
  • CHGR_AUX_DET is 0V.
  • CHGR_AUX_DET_3V3 is 3.3V.
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
