Apple ACE3 Controllers
Revision as of 17:06, 30 September 2025 by David.Lecomte (talk | contribs)
Manufacturer Apple
Code name ACE3
Release date 2023
Device type Laptop
  • Communication bus seems vastly different from ACE2. Two ADDR pins. CNTL1 and CNTL2 don't seem to be straps anymore, but look like communication lines between ACE3, retimer and repeater.
  • SMC communication can now happen either by SPMI (L27 strapped to GND) or I2C (L27 strapped to LDO_3V3). The choice so far seems to be SPMI (meaning that we can't scan for addresses anymore with our I2C scanner).
  • In DFU mode, all receptacles will register when connected to the host. But only the real DFU port will allow a Restore. The others will fail with error 4042 (dropped connexion after 10 minute timer).
Testing on a working A3113
Test date: 2025.09.26
OS: Sonoma.
DFU Restore (Tahoe): Ok.
Test 2: Replacing UF400
OS: Tahoe.
When connecting to the correct receptacle, the Terminal of the host computer outputs the following, indicating that the target Mac is detected:
Broadcast Message from root@David
        (no tty) at 15:04 CEST...
Conclusion: Nothing abnormal within the OS, but executing a DFU Restore is not possible anymore.
Test 3: Replacing UF500
OS: Tahoe.
Test 4: Replacing U5500
Test date: 2025.09.27
OS: Tahoe.
The device seems to work right away and normally (every USB function is working), until a DFU Restore is tried. It goes through without errors. Then the device loses all communication functionality through USB-C, in particular no-charging, no boosting to 20V.
Listening on the I2C1 bus shows that 0x3B is present at power up, but disappears after a few seconds. This indicates that U5500 turns on initially, and is then told to shut down. It doesn't even output its LDOs when powered through VBUS.
The problem is still present after a new DFU Restore.
The problem is still present after reinstalling the original U5500.
The device works normally after another DFU Restore (with original U5500).
The observation seems to indicate some kind of pairing of the original U5500 to the device. But it could be anything: the ROM, the SOC, the other port controllers, etc. It could be that the pairing happened the first time that IC was used, on previous tests. This is a major problem.
