| Apple ACE3 Controllers | |
| Manufacturer | Apple |
| Code name | ACE3 |
| Release date | 2023 |
| Device type | Laptop |
Testing on a working A3113
Test date: 2025.09.26
OS: Sonoma.
DFU Restore (Tahoe): Ok.
Test 2: Replacing UF400
OS: Tahoe.
When connecting to the correct receptacle, the Terminal of the host computer outputs the following, indicating that the target Mac is detected:
Broadcast Message from root@David
(no tty) at 15:04 CEST...
Conclusion: Nothing abnormal within the OS, but executing a DFU Restore is not possible anymore.
Test 3: Replacing UF500
Description: Replacing UF500 by an SN25A23P bought "new" (Mobilesentrix).
OS: Tahoe.
Test 4: Replacing U5500
Test date: 2025.09.27
Description: Replacing U5500 by an SN25A23P bought "new" (Mobilesentrix).
OS: Tahoe.
The device seems to work right away and normally (every USB function is working), until a DFU Restore is tried. It goes through without errors. Then the device loses all communication functionality through USB-C, in particular no-charging, no boosting to 20V.
Listening on the I2C1 bus shows that 0x3B is present at power up, but disappears after a few seconds. This indicates that U5500 turns on initially, and is then told to shut down.
The problem is still present after a new DFU Restore.
The problem is still present after reinstalling the original U5500.
The device works normally after another DFU Restore.
Conclusion: Major failure, and could cause major problems with after sales, since the device seems to work perfectly at first. But the next time the customer runs an update, they will lose every functionality through USB-C / Magsafe.
The observation seems to indicate some kind of pairing of the original U5500 to the device. But it could be anything: the ROM, the SOC, the other port controllers, etc.
