| Apple ACE3 Controllers | |
| Manufacturer | Apple |
| Code name | ACE3 |
| Release date | 2023 |
| Device type | Laptop |
Testing on a working A3113
Test date: 2025.09.26
OS: Sonoma.
DFU Restore (Tahoe) : Ok.
Test 2: Replacing UF400
OS: Tahoe.
When connecting to the correct receptacle, the Terminal of the host computer outputs the following, indicating that the target Mac is detected:
Broadcast Message from root@David
(no tty) at 15:04 CEST...
Conclusion: Nothing abnormal, it looks like UF400 can be replaced by an SN25A23P advertised as "new".
