| Apple ACE2 Controllers | |
| Manufacturer | Apple |
| Code name | ACE2 |
| Release date | 2019 |
| Device type | Laptop |
- Example 2: The A2242 has 3 USB-C receptacles and one Magsafe 3. It is a 4-port device.
I. Function
- Port 1, carried by pins
II.1 Determination of type
II.1.2 ACE2 purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
| Resistor value | ADDR
| 0Ω | 000 |
| 38.3kΩ | 001 |
| 84.5kΩ | 010 |
| 140kΩ | 011 |
| 205kΩ | 100 |
| 280kΩ | 101 |
| 374k | 110 |
| Infinite (floating) | 111 |
Port 1 address: 111ADDR
- The new ACE2 is OTP-ed with another address than the one it is replacing. This address will also conflict with another ACE2's address, and the whole USB-C system is down.
- The new ACE2 is OTP-ed as 0x3B and 0x3B. Then it will conflict with UG400 and the whole USB-C system is kaput.
- The new ACE2 is vanilla. It will acquire addresses 0x3F and 0x2F, conflicting with UF500 on the AP_I2C0 bus.
| UF400
UPC0 |
UF500
UPC1 |
UG400
UPC2 |
U5500
UPC5 | |
| Port 1 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
| Port 2 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
- Set
- The ACE2 outputs
PP_HV. - The
BUSPOWERpin is pulled toGND.
- The ACE2 outputs
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
