| Apple ACE2 Controllers | |
| Manufacturer | Apple |
| Code name | ACE2 |
| Release date | 2019 |
| Device type | Laptop |
- Example 2: The A2242 has 3 USB-C receptacles and one Magsafe 3. It is a 4-port device.
I. Function
- Port 1, carried by pins
II.1 Determination of type
II.1.2 ACE2 purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
| Resistor value | ADDR
| 0Ω | 000 |
| 38.3kΩ | 001 |
| 84.5kΩ | 010 |
| 140kΩ | 011 |
| 205kΩ | 100 |
| 280kΩ | 101 |
| 374k | 110 |
| Infinite (floating) | 111 |
Port 1 address: 111ADDR
The method for replacing ACE2 controllers has eluded technicians for 6 years and there were widely diverging reports, even from renowned technicians about how these ICs should be replaced. There was a consensus that these ICs are programmed, and they were behaving like the programming was tied to the device, or the ROM, or the status (Master / Slave), or something else that could not be explained logically. In September 2025, David Lecomte announced that he had made a major breakthrough, by being able to replace UG400 on an A2442, using an ACE2 coming from an A2338, and get a fully working device. Up until that time, this was thought to be impossible. He then explained in a series of videos the theory behind the success, and proceeded to showing how all four ACE2s can be replaced on these devices.
Now, here is an explanation in English of what is happening when trying to replace ACE2 controllers, and why we have to do it. Apple surrounds the landing pads of OTP-ed ACE2s with configuration resistors for ADDR, CNTL1 and CNTL2 that do not correspond to the address required by the I2C map. More precisely, the I2C addresses corresponding to this configuration are conflicting with the address of another ACE2 controller on the board. Thus, when installing replacing that controller with another one, either one of three things may happen:
- The new ACE2 is OTP-ed with another address than the one it is replacing. This address will also conflict with another ACE2's address, and the whole USB-C system is down.
- The new ACE2 is OTP-ed as 0x3B and 0x3B. Then it will conflict with UG400 and the whole USB-C system is kaput.
- The new ACE2 is vanilla. It will acquire addresses 0x3F and 0x2F, conflicting with UF500 on the AP_I2C0 bus.
Replacing UF400 or UF500 would only work with vanilla ACE2s. Using an OTP-ed controller would result in an addressing conflict with either U5500 or UG400. Since vanilla ACE2s appear with frequency slightly more than 50%, this is what gave wildly different reports when replacing those. About half of technicians (the ones lucky enough to have installed a vanilla) would report no problem reporting them; while the other half (the unlucky who installed an OTP-ed) would say it didn't work.
Therefore, the consensus when replacing these ICs was that: the safest is to just replace them from same model, same position.
| UF400
UPC0 |
UF500
UPC1 |
UG400
UPC2 |
U5500
UPC5 | |
| Port 1 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
| Port 2 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
- Set
- The ACE2 outputs
PP_HV. - The
BUSPOWERpin is pulled toGND.
- The ACE2 outputs
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
