| Apple ACE2 Controllers | |
| Manufacturer | Apple |
| Code name | ACE2 |
| Release date | 2019 |
| Device type | Laptop |
- Example 2: The A2242 has 3 USB-C receptacles and one Magsafe 3. It is a 4-port device.
I. Function
- Port 1, carried by pins
II.1 Determination of type
II.1.2 ACE2 purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
| Resistor value | ADDR
| 0Ω | 000 |
| 38.3kΩ | 001 |
| 84.5kΩ | 010 |
| 140kΩ | 011 |
| 205kΩ | 100 |
| 280kΩ | 101 |
| 374k | 110 |
| Infinite (floating) | 111 |
Port 1 address: 111ADDR
ADDR(UPC5_I2C_ADDR)floating, since this pin goes toR5650which is not present on the board. This setsADDR= 111.CNTL1(I2C_UPC5_SCL) pulled toLDO_3V3(PP3V3_UPC5_LDO)through a 1MΩ resistor. This setsCNTL1=1.CNTL2(I2C_UPC5_SDA) pulled toGNDthrough a 1MΩ resistor. This setsCNTL2=0.
The method for replacing ACE2 controllers has eluded technicians for 6 years and there were widely diverging reports, even from renowned technicians about how these ICs should be replaced. There was a consensus that these ICs are programmed, and they were behaving like the programming was tied to the device, or the ROM, or the status (Master / Slave), or something else that could not be explained logically. In September 2025, David Lecomte announced that he had made a major breakthrough, by being able to replace UG400 on an A2442, using an ACE2 coming from an A2338, and get a fully working device. Up until that time, this was thought to be impossible. He then explained in a series of videos the theory behind the success, and proceeded to showing how all four ACE2s can be replaced on these devices.
| UF400
UPC0 |
UF500
UPC1 |
UG400
UPC2 |
U5500
UPC5 | |
| Port 1 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
| Port 2 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
- Set
- The ACE2 outputs
PP_HV. - The
BUSPOWERpin is pulled toGND.
- The ACE2 outputs
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
