| Apple ACE2 Controllers | |
| Manufacturer | Apple |
| Code name | ACE2 |
| Release date | 2019 |
| Device type | Laptop |
- Example 2: The A2242 has 3 USB-C receptacles and one Magsafe 3. It is a 4-port device.
I. Function
- Port 1, carried by pins
B7,A6andC8, respectively forSDA,SCLandIRQ. This interface is controlled bu the SMC, which is part of the T2 SOC or Apple Silicon SOC, depending on the architecture.
II.1 Determination of type
II.1.2 ACE2 purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
| Resistor value | ADDR
| 0Ω | 000 |
| 38.3kΩ | 001 |
| 84.5kΩ | 010 |
| 140kΩ | 011 |
| 205kΩ | 100 |
| 280kΩ | 101 |
| 374k | 110 |
| Infinite (floating) | 111 |
Port 1 address: 111ADDR
ADDR(UPC5_I2C_ADDR)floating, since this pin goes toR5650which is not present on the board. This setsADDR= 111.CNTL1(I2C_UPC5_SCL) pulled toLDO_3V3(PP3V3_UPC5_LDO)through a 1MΩ resistor. This setsCNTL1=1.CNTL2(I2C_UPC5_SDA) pulled toGNDthrough a 1MΩ resistor. This setsCNTL2=0.
The method for replacing ACE2 controllers has eluded technicians for 6 years and there were widely diverging reports, even from renowned technicians about how these ICs should be replaced. There was a consensus that these ICs are programmed, and they were behaving like the programming was tied to the device, or the ROM, or the status (Master / Slave), or something else that could not be explained logically. In September 2025, David Lecomte announced that he had made a major breakthrough, by being able to replace UG400 on an A2442, using an ACE2 coming from an A2338, and get a fully working device. Up until that time, this was thought to be impossible. He then explained in a series of videos the theory behind the success, and proceeded to showing how all four ACE2s can be replaced on these devices.
III.1 Rule 1: Don't be an idiot.
III.2 Case 1: You have a donor board for the same device
III.2 Case 2: You do not have a donor board for the same device
III.2.1 Configuring the I2C addresses
| UF400
UPC0 |
UF500
UPC1 |
UG400
UPC2 |
U5500
UPC5 | |
| Port 1 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
| Port 2 | 0x38
111000b |
0x3F
111111b |
0x3B
111011b |
0x3A
111010b |
- Set
III.2.2 Fixing lingering issues.
III.2.2.1 No PD negotiation when the board is out of the housing, but it works and charges when the device is assembled and powered up
- The ACE2 outputs
PP_HV. - The
BUSPOWERpin is pulled toGND.
III.2.2.2 No PD negotiation, whether the board is out or in housing.
- The ACE2 outputs
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
