Apple ACE2 Controllers
Revision as of 13:52, 25 September 2025 by David.Lecomte (talk | contribs)
Manufacturer Apple
Code name ACE2
Release date
Device type Laptop
I. Function
  • Port 2, carried by pins B7, A6 and C8, respectively for SDA, SCL and IRQ. This interface is controlled bu the SMC, which is part of the T2 SOC or Apple Silicon SOC, depending on the architecture.
II.1 Determination of type
II.1.1 ACE2s pulled from a donor board
II.1.2 ACEs purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
  • M19, which we will call ADDR. This pin connected to GND through a resistor, or floating, and is assigned a binary value depending on the value of that resistor, according to the table:
Resistor value ADDR
000
38.3kΩ 001
84.5kΩ 010
140kΩ 011
205kΩ 100
280kΩ 101
374k 110
Infinite (floating) 111
Port 1 address: 111ADDR
Port 2 address: 1CNTL2 CNTL2 ADDR
  • ADDR (UPC5_I2C_ADDR)floating, since this pin goes to R5650 which is not present on the board. This sets ADDR = 111.
The method for replacing ACE2 controllers has eluded technicians for 6 years and there were widely diverging reports, even from renowned technicians about how these ICs should be replaced. There was a consensus that these ICs are programmed, and they were behaving like the programming was tied to the device, or the ROM, or the status (Master / Slave), or something else that could not be explained logically. In September 2025, David Lecomte announced that he had made a major breakthrough, by being able to replace UG400 on an A2442, using an ACE2 coming from an A2338. Up until that time, this was thought to be impossible. He then explained in a series of videos the theory behind the success, and proceeded to showing how all four ACE2s can be replaced on these devices.
III.1 Rule 1: Don't be an idiot.
III.2 Case 1: You have a donor board for the same device
III.2 Case 2: You do not have a donor board for the same device
III.2.1 Configuring the I2C addresses
AP_I2C0
SMC_I2C1
UF400
UPC0
UF500
UPC1
UG400
UPC2
U5500
UPC5
Port 1 0x38
111000b
0x3F
111111b
0x3B
111011b
0x3A
111010b
Port 2 0x38
111000b
0x3F
111111b
0x3B
111011b
0x3A
111010b
III.2.2 Lingering issues.
III.2.2.1 No PD negotiation when the board is out of the housing, but it works and charges when the device is assembled and powered up
III.2.2.2 No PD negotiation, whether the board is out or in housing.
  • No PPBUS_AON.
  • CHGR_AUX_DET is 0V.
  • CHGR_AUX_DET_3V3 is 3.3V.
IV. Known-tested replacements
Replacing UG400.
Replacing UF400 or UF500.
Replacing U5500 on an A2442.
No lingering issue.
Replacing U5500.
V. About the ROM
