Apple ACE2 Controllers
Revision as of 11:26, 25 September 2025 by David.Lecomte (talk | contribs) (Just saving.)
I. Function
  • Port 2, carried by pins B7, A6 and C8, respectively for SDA, SCL and IRQ. This interface is controlled bu the SMC, which is part of the T2 SOC or Apple Silicon SOC, depending on the architecture.
II.1 Determination of type
II.1.1 ACE2s pulled from a donor board
II.1.2 ACEs purchased as new
II.1.2 ACE2 of unknown origin
II.2 I2C addresses decoding
  • M19, which we will call ADDR. This pin connected to GND through a resistor, or floating, and is assigned a binary value depending on the value of that resistor, according to the table:
Resistor value ADDR
000
38.3kΩ 001
84.5kΩ 010
140kΩ 011
205kΩ 100
280kΩ 101
374k 110
Infinite (floating) 111
Port 1 address: 111ADDR
Port 2 address: 1CNTL2 CNTL2 ADDR
  • ADDR (UPC5_I2C_ADDR)floating, since this pin goes to R5650 which is not present on the board. This sets ADDR = 111.
III.1 Rule 1: Don't be an idiot.
III.2 Case 1: You have a donor board for the same device
III.2 Case 2: You do not have a donor board for the same device
It might be difficult to have donor boards for every device that one has to fix, be it only on the matter of price: donor boards for Pro / Max boards can cost in the 200USD ballpark, or even more if the device is recent. In this case, your replacement ACE2 should be a vanilla one. Before proceeding, here are the things you should do:
AP_I2C0
ACE2 - 0 (DEBUG) USB-C 0 0x3A 0x70
SMC_I2C1
Every schematic up to now has such a page
