How To Fix an iPhone 17 Air That Randomly Restarts
Revision as of 02:38, 20 September 2025 by IamMyron07 (talk | contribs) (→‎Solution)
Device iPhone 17 Air
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 17 Air to randomly restart every few minutes. For the iPhone 17 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 17 Air series are:
  • Wireless Charging Flex - The flex that's attached to the back glass. It must be plugged in & not damaged, otherwise it will restart every 3 minutes
  • Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged by water/drops or when someone has replaced the port with a bad/aftermarket one.
iPhone 15 - FPCs to Inspect for 3 Min Restart
* After a back glass repair, the iPhone will restart on its own every few minutes * After a hard drop, the iPhone will restart every 3 minutes. * After a screen repair, the iPhone will bootloop every 3 minutes * After replacing the charging port flex, the device will auto restart on its own randomly. * The iPhone will reboot randomly when using it. * The iPhone will seem to freeze and restart every 2-5 minutes.iPhone 15 - FPCs to Inspect for 3 Min Restart
For this model, look for where it says "SMC PANIC - ASSERTION FAILED" ... "Sensor Array" .. "23...."
If you see:
  • 33554432 [0x2000000] - it's the Wireless Charging Flex (Back Glass)
    • Could be a sandwich issue
iPhone 15 - Charging Port Flex
  • 58720256 [0x3800000] - it's the Charging Port Flex
    • Make sure the Air Pressure Sensor is plugged in
    • Test with OEM or Premium. Aftermarket parts have a high defect rate
  • Bad or damaged flex
